System:
Windows XP
ARM 1.04
tRio alpha5
I have been playing with tRio the past few weeks and things have been working well. I ripped a couple of songs with WMP9 using CBR encoding (i.e. not VBR, and not the lossless codec) at 160kps. Those files worked fine with both tRio/ARM and the default ARM receiver.arf.
Then today, they stopped working with tRio. The tRio console gives a huge stack trace. The top of the stack says:
trio.player.TRioPlayerServerException: Unexpected error populated tune details from Audio Receiver Manager server. See tRio logs for details.
I can't find any tRio logs. Where are they on a windows system?
Below is a full stack trace when it tries to expand all songs by artist.
Any ideas?
at trio.player.TRioPlayerARMServer.populateDetails(Unknown Source)
at trio.player.TRioPlayerTune.populateDetails(Unknown Source)
at trio.player.TRioPlayerTune.getAlbumTitle(Unknown Source)
at trio.player.TRioPlayerTune.getAttribute(Unknown Source)
at trio.player.TRioPlayerTuneComparator.compare(Unknown Source)
at java.util.TreeMap.compare(Unknown Source)
at java.util.TreeMap.put(Unknown Source)
at java.util.TreeSet.add(Unknown Source)
at trio.player.TRioPlayerARMServer.doResults(Unknown Source)
at trio.player.TRioPlayerARMServer.listTunes(Unknown Source)
at trio.player.TRioPlayerARMServer.listTunesSH(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at sun.rmi.server.UnicastServerRef.dispatch(Unknown Source)
at sun.rmi.transport.Transport$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at sun.rmi.transport.Transport.serviceCall(Unknown Source)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(Unknown Source)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(Unknown Sour
ce)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.NumberFormatException: f?160
at java.lang.Integer.parseInt(Unknown Source)
... 22 more
Updating config file
Error: java.lang.NumberFormatException: f?160
at trio.player.TRioPlayerTune.getInfo(Unknown Source)
at trio.player.TRioPlayerPlaybackPanel.getField(Unknown Source)
at trio.player.TRioPlayerPlaybackPanel.expandValue(Unknown Source)
at trio.player.TRioPlayerPlaybackPanel.updateField(Unknown Source)
at trio.player.TRioPlayerPlaybackPanel.updateFields(Unknown Source)
at trio.player.TRioPlayerFrame.playbackUpdate(Unknown Source)
at trio.player.TRioPlayerUnitStream.playbackUpdate(Unknown Source)
at trio.player.TRioPlayerStreamImpl.notifyPlaybackUpdate(Unknown Source)
at trio.player.TRioPlayerSequencedStream.sequencerUpdated(Unknown Source
at trio.player.TRioPlayerQueue$QueueNotificationDispatcher.run(Unknown S
ource)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
ource)
... 19 more
java.lang.NullPointerException
ource)
