It's all proprietary. Really, if you're skilled enough to solder it, you're probably skilled enough to figure out what might be fried, loose, blown or whatever. I know I'm not. You might check the FAQ for information about fuses, since if that's your problem maybe you're lucky (but not overly so). The people who are most likely to be able to guess at your problem probably aren't awake just yet.
