Too wide to pass through the fascia, or too wide to fit in the cage behind the fascia?
The sled is too wide to fit the cage and the Empeg it's self wont pass through the hole in the dash.
The Toyota MR2 and Celica use their own cage - two metal plates, one plate is bolted to each side of their own players.
Sounds similair. It is similair looking at the plates, but the locating lugs on the Prado are too long, so probably will be best off making new plates.
It is possible to modify the plates and the Empeg sled so that the two fit together. I am guessing that other Toyota models use the same/similar setup. In the Celica and MR2, the fascia needs to be modified to allow the Empeg to dock into the sled, also.
I thought about modifying the plates. But that probably wouldn't work, I think I'll have to make some new ones and grind out the space for the sled & make the hole bigger for the empeg itself.
Looks like I'm going to have to do it the hard way ahh well... thanks neway
