Ok, I set suppress notify = 1, now the player starts up and goes into standby mode every time. The last 2 powerfail statements in the boot cycle happen once I turn the empeg on after it has booted up. I can check the leaf spring in the power connector but I am pretty sure it is fine, the connector does not get used much.
Here it is, 2 boots.
empeg-car bootstrap v1.02 20001106 (
[email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v413 (
[email protected]) (gcc version 2.95.3 20010315 (release)) #3 Thu Dec 9 20:42:29 EST 2004
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 120001063) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Powerfail is now disabled (1)
Powerfail is now enabled (0)
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
Powerfail line current level is 0
empeg state support initialised 0089/88c1 (save to d0004200).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-212000, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
smc chip id/revision 0x3349
smc9194.c:v0.12 03/06/96 by Erik Stahlman (
[email protected])
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:18:04:27
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly.
Mounting proc
No secondary hard disk
Press 'q' now to go intStarting player
Timezone: Atlantic/South_Georgia
Hijack: intercepting config.ini
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
[email protected])
e000 v1.04
Copying kernel...
[email protected])
Partition check:
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player
Vcb: 0x4086d000
