Alternately you can use the /PAE (Physical Address Extention) switch, which turns on 64 bit memory addressing, at least on the W2k Server (not sure which versions) & 2003 Server (Enterprise edition & up). This lets you address >4GB in system RAM, if your motherboard supports it, that is.
-Zeke
WWFSMD?
