I was amazed, I really couldn't believe that they'd not put it into the ECU, morons!
That's the exact opposite of the Smart, everythings on a CAN bus and as a result a lot of the options you would imagine require hardware changes actually just require a poke of the ECU, both the full auto gearbox upgrade and cruise are a case of adding a button or two to the loom and enabling it in the ECU. I'm sure if you wanted to swap the action of the turn indicators you could do it in software.
