I'd like to recommend the UK tyre fitting service that I used the other day. I always make sure that we have top quality tyres fitted to our cars, so I am always looking for a cheap source of tyres.
In the past I have used
http://www.blackcircles.com/ and
http://mytyres.co.uk/ to get good prices on tyres. Both these services courier the tyres to you and then you have to take them to a local fitter to get them fitted.
When I discovered the other day that I had less than 20 hours to get a new set of tyres it was obvious that my usual sources weren't going to be able to deliver on time.
After a bit of Googling I found a few mobile fitters, one of them was
http://www.event-tyres.co.uk/I emailed them at about 11pm. At 8am then next morning they phoned to say that they could supply the exact tyres I wanted and that they could fit them that day. By 2pm the same day they had turned up and fitted them.
On top of that speedy service they were also cheaper than both blackcirles and mytyres.
Highly recommended.
P.S. the fitter actually used a torque wrench to refit the wheel studs, long time since I have seen that...
