As long as SQL is completely down, you should be able to backup and restore the folders and have it work.
A good / quick way to test is to shut it down, rename the existing folder and copy it back to the original name. See if it starts cleanly. If it does, you have just created your first successful backup; otherwise, shut it down again, rename the original back and restart.
Paul Grzelak
