is there an easy way to hook up a pda via serial in the sled and capture the log?
That depends entirely on the PDA and if it's got a serial port you can use.
( i saw the note in the faq about the serial connector in the sled, but i have not absorbed its meaning yet.)
It means, in some cases, you've got to wire up your own serial cable if you want to grab serial data while it's in a docking sled.
