I set up an unattended WindowsXP installation CD that has SP's and updated all integrated. It also installs Office and other basic every-computer apps. It works perfect. Now what I would like to do is put that CD on a server and have clients boot via PXE and run the installer.
So far, I have a RHEL machine running dhcpd and tftp-hpa. The server is an oscar primary node, which was set up to install the os on the clients (and it worked). Now I'm trying to adjust that configuration to install Windows.
Here is the dhcp.conf file oscar set up:
deny unknown-clients;
option subnet-mask 255.255.255.0;
option broadcast-address 192.168.0.255;
option domain-name "";
option routers 192.168.0.1;
ddns-update-style none; # For dhpcd version 3
#set up eth1
subnet 192.168.0.0 netmask 255.255.255.0 {
group {
host oscarnode1{
hardware ethernet 00:04:76:17:DD:A2;
fixed-address 192.168.0.100;
filename "pxelinux.0";
option domain-name "oscardomain";
host oscarnode2{
hardware ethernet 00:04:76:17:BC:4D;
fixed-address 192.168.0.101;
host oscarnode3{
hardware ethernet 00:04:75:85:04:BB;
fixed-address 192.168.0.102;
# This entry ignores requests on eth0...
subnet 161.130.224.0 netmask 255.255.224.0 {
not authoritative;
I want all requests made to eth1 (192.168.0.1) to be allowed, so I edited the file to the following:
allow booting;
allow bootp;
ddns-update-style ad-hoc; #Get an error without this, not sure what it does
option domain-name "winsetup.com";
option domain-name-servers 192.168.0.1;
group {
next-server 192.168.0.1;
filename "/tftpboot/pxelinux.0";
range 192.168.0.100 192.168.0.200;
not authoritative;
That should be okay, right? My clients are getting an IP, so I think that is working.
In the /tftpboot/pxelinux.cfg directory, the config file used is just "default". oscar created this config file:
DEFAULT systemimager
LABEL systemimager
DISPLAY message.txt
PROMPT 1
TIMEOUT 50
KERNEL kernel
APPEND vga=extended initrd=initrd.img root=/dev/ram
I changed the file to this:
DEFAULT winboot
LABEL systemimager
DISPLAY message.txt
PROMPT 1
TIMEOUT 70
KERNEL kernel
LABEL winboot
DISPLAY winboot-msg.txt
PROMPT 1
TIMEOUT 70
KERNEL
APPEND
I'm not sure what to put in the KERNEL and APPEND parts of the winboot section. Either way, my clients get an ip from dhcp but tftp times out. Shouldn't tftp work like this, just give an error?
