This shouldn't be the case. Have you done anything to the EQ, the loudness, or the Bass and Treble settings in Hijack?
No. Everything else is set as it was.
You should be able to set it at 0 db without problem. That's what I do with both of my vehicles (Pioneer with AUX-IN adapter). What model Alpine do you have? If it requires an adapter for AUX, what model adapter and is it a true AUX input or a FM modulator?
It is a CDA-9805. To my knowledge, there is no adapter. The alpine does have an AUX input, which is where it is set.
And just a note, on 1.03, the empeg was set at -6.5db and around 21 on the alpine, it was about the peak of what I would listen to. Now, with the settings on the empeg way lower (-16db), and the alpine on 21, it is the same volume. So, it seems that there is some type of volume difference in the software revisions.
Any more input?
Edited by djdrock (30/01/2006 20:59)
1993 MR2 MK2a 32gb. 1991 NSX unfortunately with and IPOD.
