No primary hard disk
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComplůStarting player
This is a bug in the builder software. It created the root partition, and copied the player software and kernel into place. But there was an error in creating the music partition. You can see in the above fragment that the player software loaded, so root is okay, but it could not find the primary music partition.
If the disk does not have any music on it (and I would expect this is the case if you ran the builder software), you have two options. You can build the music filesystem manually or rerun the builder a second time. Given that this is a 100GB drive, it is likely that the builder software did not have enough memory available to perform an mke2fs on the drive.
Paul Grzelak
