No, it's just that when you load download, it has the ability to either let the application (the player software) or a background application use the serial port, instead of only the player. The default setting on first install is background app. If you want to retain the original behaviour, you have to go into HiJack and set it - it's nothing to do with A11.
Ah... makes sense now. Thanks guys.
Brad B.
