Okay. Lost me now. Why would you want to replace the empeg with something that whilst cheaper, is exactly the same physical size/shape and does less?
because it could potentially be produced for less than the cost of the 160GB drive in it. (think chip on board and metalized plastic)
There aren't that many off the shelf laptop PC parts. The only ones I can readily think of are HDs, miniPCI cards and memory. Everything else is usually part of a single motherboard that is custom made to fit into that specific laptop. I think you could just about wedge a NanoITX board into a DIN slot but it'd be a tight fit with the HDs and PSU as well.
What I meant by off the shelf was the processor and related chip sets, it would be in essence a custom PC in a DIN case with the extra unneeded crap omitted. IE no
Battery charger,PCMCIA,PS2,keyboard/mouse interface,video card,printer port.
just OLED display w/touch screen interface,serial ports,USB on the go,fire wire,bluetooth,irda,802.11 something,kick ass audio chip set w/digital out+RCA,ATA interface,a few geek ports. and being an X86 compatible it can run Linux. The same board could also be mounted in 1.5 or 2 DIN case for larger displays or a potential 3.5" drive.
For the tuner I'd use a CATV brick as they tune from almost DC to about 550MHz, thus allowing AM, all broad cast TV audio, FM, CB, FRS+GMRS, a bunch of HAM bands, and if you can get quadrature from the IF section and feed it into a DSP you can get SSB reception and a slew of digital modes including DAB, DRM (can be decoded via sound card using DReaM, and probably a few others I've forgotten.
The only difference between science fiction and reality is about 60 years.
100GB MK2 Green 080000171 + OEM tuner
v3.00a11 hijack v450 jEmpload v70
