I haven't gone through Roger's steps for a single drive player, but yes, if you have the drive plugged in as the primary drive, then the commands should be for drive0 instead of drive1.
The thing you need to note is that the steps only work if the disk is already partitioned and partially formatted -- as it would be if you've tried the builder and it's failed (because it's usually only formatting the music partition that fails).
That's why my instructions assume you've got a working primary disk and you're doing the second disk. Once you've done that, you can take the old primary out, promote the newly-formatted disk to primary, and then put in the other new disk as the secondary.
However, srhodes obviously got it all going, so cool. Congratulations on your larger disks.
roger
