Yeah, OK, upload.exe is hard coded to accept the parameters 1-4 only.
If you've got a C compiler, you're welcome to fidget with it. Source code attached.
If you can attach the source code in a form that's not mangled, it'd be easier to fidget with. Try a ZIP file.
It doesn't look mangled to me. I clicked the attachment, and told firefox to save to disk. Opened in vim just fine. Unless, of course, you're calling Tony's coding standards mangled... in which case using a zip file isn't going to help much.
