I didn't answer about the wiring because I posted the message after the time I'm allowed to go play outside with my truck
Not to mention I have to take my whole dash off to see inside
I will disconnect the RCAs after work, that's a good idea. I can only HOPE it's the amplifier!
As for the wiring, I will check that after I do the amp test. I haven't had a problem with it until just recently, so I suspect it is just my Kenwood's time to die. I guess if I spent seven years under a seat at 100degrees, I'd probably click and pop too!
