Hi all,
The RTS and CTS shouldn't matter as only the RX, TX and ground are connected to the wideband serial connector.
I just got back from testing it with the empeg connected to an AC power supply (out of the sled) using the connector on the back of the unit. I totally expected it to work but it didn't.
So, the problem seems to have to do with the installation of the wideband in the car. When I tested it out of the car I was using a small battery to power the wideband and a wall wart to power the empeg. Now the wideband is using the car battery. I'm not sure what the difference is.
The wideband is communicating with my laptop fine, just not with the empeg either in the sled or out. I am going to connect an ethernet cable to the empeg and put some debugging code in the program and see if it is seeing any input over the serial port.
I guess I could also just try cat /dev/ttyS1 to see if anything is coming in over the port...
Edited by jag (28/09/2006 00:11)
