I am wondering if there is a way to configure the startup items as to what loads first, and is there any danger in doing so
Yep. Replace all of the items in the Startup group with a shortcut to a batch file that runs them in the correct order. You can even put delays in there.
You can do the same for the Run key, as well.
There shouldn't be any danger in doing so.
