The changer has almost certainly got line-outs, which will feed into the empeg's line inputs. The problem is the cd changer protocol - you'd have to reverse engineer this, then probably implement it on a PIC and hook this up to the empeg serial port. Changer manufacturers don't tend to give out specs, which is the other problem.
Hugo
