70 degrees?! Wow! I was lucky I guess and didn't have to any bending. I used a screwdriver to pull on the tabs a bit as I slid the cover... I had to do it bit by bit and from side to side. Took a minute or so, but no bending. The drive sled was tricky. I remember it not coming out right away. I had to pivot it a bit and then it came free. The only reason I am mentioning this is so that others are not scared from doing a drive add-on...
The FAQ IS a livesaver!
32GB (JUST UPGRADED!) Mk. II BLUE
Detroit, MI USA
www.PfeifferBeer.com
Brad B.
