Here is my boot capture. I've tried Cntrl+C, Q, and Cntrl-Break
Empeg screen says Building music databases...
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v445 ([email protected]) (gcc version 2.95.3 20010315 (release)) #2 Sat Mar 11 11:11:45 EST 2006
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 40104282) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (988k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9dfb8
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004700).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IC25N080ATMR04-0, ATA DISK drive
hda: HTS421212H9AT00, ATA DISK drive
hda: HTS421212H9AT00, 114473MB w/7528kB Cache, CHS=14593/255/63
hdb: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:ba
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...
Mounting proc
hijack: removed menu entry: "Hard Disk Detection"
khttpd: listening on port 80
kftpd: listening on port 21
Thanks in advance!
