the output:
smartctl version 5.33 [arm-empeg-linux-gnu] Copyright (C) 2002-4 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION ===
Device Model: ST9808211A
Serial Number: 3LF3D3HA
Firmware Version: 3.05
User Capacity: 80,026,361,856 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 6
ATA Standard is: ATA/ATAPI-6 T13 1410D revision 2
Local Time is: Sat May 31 14:17:27 2008 /usr/local/armtools
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
Total time to complete Offline
data collection: ( 426) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off supp
ort.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
No General Purpose Logging support.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 84) minutes.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_
FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x0a0f 060 042 034 Pre-fail Always -
151238706
3 Spin_Up_Time 0x0003 095 094 000 Pre-fail Always -
0
4 Start_Stop_Count 0x0032 099 099 020 Old_age Always -
1421
5 Reallocated_Sector_Ct 0x0033 071 071 036 Pre-fail Always -
1195
7 Seek_Error_Rate 0x000f 079 060 030 Pre-fail Always -
94641337
9 Power_On_Hours 0x0032 096 096 000 Old_age Always -
3727
10 Spin_Retry_Count 0x0013 100 100 034 Pre-fail Always -
0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always -
635
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always -
635
193 Load_Cycle_Count 0x0032 090 090 000 Old_age Always -
20269
194 Temperature_Celsius 0x0022 031 066 000 Old_age Always -
31 (Lifetime Min/Max 0/2)
195 Hardware_ECC_Recovered 0x001a 060 042 000 Old_age Always -
151238706
197 Current_Pending_Sector 0x0012 002 001 000 Old_age Always -
1918
198 Offline_Uncorrectable 0x0010 002 001 000 Old_age Offline -
1918
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always -
0
200 Multi_Zone_Error_Rate 0x0000 100 253 000 Old_age Offline -
0
202 TA_Increase_Count 0x0032 100 253 000 Old_age Always -
0
SMART Error Log Version: 1
Warning: ATA error count 0 inconsistent with error log pointer 4
ATA Error Count: 0
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 0 occurred at disk power-on lifetime: 3887 hours (161 days + 23 hours)
When the command that caused the error occurred, the device was in a vendor sp
ecific state.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
51 01 01 00 00 43 a1 Error: UNC, IDNF, AMNF at LBA = 0x01430000 = 21168128
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
40 20 fe f9 6f 00 00 f6 12d+10:16:25.350 READ VERIFY SECTOR(S)
00 20 fd f9 6f 00 00 f6 00:00:43.016 NOP [Reserved subcommand]
00 20 fb f9 6f 00 00 f6 00:00:40.968 NOP [Reserved subcommand]
00 20 f9 f9 6f 00 00 f6 00:00:38.920 NOP [Reserved subcommand]
00 20 f7 f9 6f 00 00 f6 00:00:36.872 NOP [Reserved subcommand]
Error -1 occurred at disk power-on lifetime: 34824 hours (1451 days + 0 hours)
When the command that caused the error occurred, the device was in an unknown
state.
19 43 f7 51 01 00 00 Error:
00 19 f7 20 0a 76 0d 2f 00:14:28.352 NOP [Reserved subcommand]
00 18 f7 20 ce 74 0d ef 00:14:11.968 NOP [Reserved subcommand]
00 18 f7 20 97 74 0d af 00:14:11.968 NOP [Reserved subcommand]
00 18 f7 20 8e 74 0d 6f 00:14:11.968 NOP [Reserved subcommand]
00 18 f7 20 31 98 0d 2f 00:14:11.968 NOP [Reserved subcommand]
Error -2 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
ecific state.
d0 00 6f 16 f7 51 01
76 cf 6f 16 f7 20 0a 02 22d+22:06:06.861 SEEK [RET-4]
74 cf 2f 16 f7 20 ce 02 22d+16:20:57.485 SEEK [RET-4]
74 cf ef 15 f7 20 97 02 22d+15:20:53.005 SEEK [RET-4]
74 cf af 15 f7 20 8e 02 22d+15:11:03.181 SEEK [RET-4]
74 cf 6f 15 f7 20 87 02 22d+15:03:24.429 SEEK [RET-4]
Error -3 occurred at disk power-on lifetime: 3721 hours (155 days + 1 hours)
When the command that caused the error occurred, the device was active or idle
40 51 00 d0 ef 12 f7 Error: UNC at LBA = 0x0712efd0 = 118681552
20 00 02 cf ef 12 f7 00 6d+09:37:51.899 READ SECTOR(S)
20 00 02 cf af 12 f7 00 6d+09:37:51.888 READ SECTOR(S)
20 00 02 cf 6f 12 f7 00 6d+09:37:51.883 READ SECTOR(S)
20 00 02 cf 2f 12 f7 00 6d+09:37:51.879 READ SECTOR(S)
20 00 02 cf ef 11 f7 00 6d+09:37:51.873 READ SECTOR(S)
Error -4 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
state.
00 00 00 43 a1 01 00
d0 00 0d 00 00 40 00 8a 40d+09:21:05.071 [RESERVED]
cf 00 0d 00 00 00 02 81 40d+04:43:38.927 [RESERVED]
cf 00 0d 00 00 00 02 76 40d+04:43:38.863 [RESERVED]
cf 00 0d 00 00 00 02 6f 40d+04:43:38.799 [RESERVED]
cf ff 0c 00 00 00 02 1e 40d+04:43:38.735 [RESERVED]
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA
_of_first_error
# 1 Extended offline Completed: read failure 90% 3726 101
617328
# 2 Short offline Completed: read failure 90% 3337 101
517771
# 3 Short offline Completed: read failure 90% 3337 101
517771
# 4 Short offline Interrupted (host reset) 90% 3337 -
# 5 Short offline Completed: read failure 90% 3336 176
31400
# 6 Short offline Completed: read failure 90% 3106 101
458623
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
empeg:/tmp#
