Thanks Guys...
I'm curious, where is your yellow cable from the sled connected to?
I will have to look closer, but it appears it has been cut and thrown away. If I could find another wiring harness I might be able to retrofit it to the current set up. They created a special gauge pod with my sled that I would like to continue to use. I specifically asked them to make no permanent changes to the sled... but I said the exact same thing about the wiring harness. mad
EDIT: got your post confused with another thread. Ooops!
That actually sounds like sounds like my thread I linked to in my original post. eek I would love to fix this aspect of my install, but in the short term I fear I do not have the parts or the know how to do so.
If the yellow memory wire is still attached to the sled, is the "Filter & Fuse" part something I can pick up somewhere and easily patch in?
I am familiar with the technique of reattaching wires to the sled contacts, but I have no soldering tools or skills.
Brian H. Johnson
MK2 36GB Blue, currently on life support
"RIP RCR..."
