Originally Posted By: Cris
On the mini, it's worth pointing out the new Mini's come with much improved graphics capability but they still run off 2.5" drives, not sure if they ship with 7200rpm's or not?
If you're at all serious about editing you shouldn't put your capture or scratch on the same disc as your system. Use an external disc instead, the mini now has FW800 or you could just use USB2 either work pretty well.
