/dev/audio is vaguely standard, except that it *requires* fills of DMA buffer size (4608 bytes) and is locked at 44.1khz stereo. The buffer fill bit is a bug, but it's likely to stay locked at that rate - we can't actually change the rate (the player does interpolation & flash stuff for lower bitrates).
The mixer calls are pretty standard I believe, though there are lots of other bits for controlling the DSP - many of which we simply can't document as we're under NDA with the docs on the DSP.
Hugo
