I have now got a full boot log (posted below) - again pretty baffling, it all looks clean, no error messages to speak of. The only thing I don't like is the gw=ffffffff line(s).
Is anyone in a position to compare it with a working log?
empeg-net v1.01 20000710 (
[email protected])
Clearing 4Mb of RAM...
Copying kernel...
Calling linux kernel...
Uncompressing Linux............................. done, booting the kernel.
boot no options
Linux version 2.2.14-rmk4-mercury17-v1.01 (
[email protected])
(gcc version 2.95.2 19991024 (release)) #73 Fri Jul 14 17:37:29 BST 2000
Calibrating delay loop... 65.33 BogoMIPS
Memory: 3116k/4M available (752k code, 20k reserved, 200k data, 8k init)
Dentry hash table entries: 512 (order 0, 4k)
Buffer cache hash table entries: 2048 (order 1, 8k)
Page cache hash table entries: 1024 (order 0, 4k)
Linux NET4.0 for Linux 2.2
NET4: Unix domain sockets 1.0 for Linux NET4.0.
IP Protocols: ICMP, UDP, TCP
TCP: Hash tables configured (ehash 4096 bhash 4096)
Starting kswapd v 1.5
empeg clps7212 audio driver initialized
mercury display initialised.
mercury infra-red support initialised.
mercury rotary support initialised.
mercury buttons support initialised.
Probing for cs8900a
eth0: cs8900 rev J found at 0x300 media RJ-45, IRQ 7 00 90 00 11 4c 01
IP-Config: Entered.
eth0: using 10Base-T (RJ-45)
IP-Config: Opened eth0 (able=28)
DHCP: XID=57f3b1bb
Sending DHCP / UPnP requests...IP-Config: UPnP trying address 169.254.207.17
DHCP: Got extension 35 02
DHCP: Got extension 01 ff ff ff 00
DHCP: Got extension 3a 00 02 a3 00
DHCP: Got extension 3b 00 04 9d 40
DHCP: Got extension 33 00 05 46 00
DHCP: Got extension 36 c0 a8 00 0e
DHCP: Gateway is ffffffff
. OK
DHCP lease time (d:hh:mm) 4:00:00
IP-Config: Got DHCP answer from 192.168.0.14, my address is 192.168.0.111
Sending SSDP requests....SSDP: NFS server at 192.168.0.11:21076
OK
IP-Config: device=eth0, local=6f00a8c0, server=0b00a8c0, boot=0b00a8c0, gw=ffffffff, mask=00ffffff
IP-Config: host=192.168.0.111, domain=(none), path=`'
Looking up port of RPC 100003/2 on 192.168.0.11
Looking up port of RPC 100005/1 on 192.168.0.11
VFS: Mounted root (NFS filesystem) readonly.
Freeing unused kernel memory: 8k init
Bootstrap code size 348
Found kernel image "/zImage", size: 380620
Loading kernel image at virt c0180000... loaded
Found pna driver image "/il-binary.o", size: 0
Loading pna module image at virt c03e0000... loaded
Command line: "ip=192.168.0.111:192.168.0.11:21076::255.255.255.0:::off loadmodule=0xc03e0000"
Copying bootstrap code...
Calling architecture bootstrap loader...
c0180000 0005cecc c01de000 c01dd000
Uncompressing Linux........................... done, booting the kernel.
boot no options
Linux version 2.2.14-rmk4-mercury19 (robin@victoria)
(gcc version 3.4.2 (release) (CodeSourcery ARM Q3D 2004)) #1 Mon Jul 16 17:37:22 BST 2007
IP-Config: Parameter #0: `192.168.0.111'
IP-Config: Parameter #1: `192.168.0.11'
IP-Config: Parameter #2: `21076'
IP-Config: Parameter #4: `255.255.255.0'
IP-Config: Parameter #7: `off'
Memory: 3156k/4M available (712k code, 20k reserved, 200k data, 8k init)
Probing for cs8900a
IP-Config: Entered.
IP-Config: Opened eth0 (able=0)
init (1): unsupported llseek call standard
sendto: Network is unreachable
No connection to slimserver
