You have to consiter that the DSP can only handel 20 bands in total, and each channels you have, must shar the DSP.
There is there for only a limited posibilitys of combinations:
20 band / (L/R  + F/B = 4 chanels) =  5 band EQ
20 band / (L/R = 2 chanels) = 10 band EQ
20 band / (MONO + F/B = 2 chanels) = 10 band EQ
20 band / (MONO = 1 chanels) = 20 band EQ
Pleas notis that the to last is only MONO and hwo wants that !!
So I donīt think that there will come sutch a setting.(who know!)
the only solution I know is that you migth diffrent the bands per channels eg.
14 L/R and 6 F/B
by using some fansy calculations on the settings you will be abel to more bands than there is.
lets for a moment take the lest chanel and F/B ther we have 10 band EQ avalible.
by aplaying the chanels dynamic we will be abel to calculate witch area that diff betwne front an rear and there by have more avalible for general setting
fx. we only change the bass and tribble setting (10 -2) 8 is avalible for general setting and by interpolating where the ajustments are made it will be more transparant howe we asain the bands
Mark
emaks rouls #10677
Mark wait for mk III with a USB Host/slave (USB->GPS)(USB->Bluetooth)(USB->You name it)
