This is sort of following on from a post I made a while ago regarding putting SSD's in some Poweredges. It appears 3.5 inch drives are pretty expensive compared to their similar specced 2.5 inch bretheren.
2.5 inch bays are becoming quite rare in the new poweredge models, only the higher end models support them now and the specs of those machines are a little OTT (not to mention expensive). So i'm wondering if anyone has come across a bracket that would position the 2.5 SATA disc in the right position so it would fit in a Dell 3.5 drive caddy and connect properly to the SATA backplane on the server.
