Yep. That should work. I don't know that anyone has actually tried it yet, though. Probably the biggest concern is whether there's enough space inside the empeg case to handle even that small adapter.
If that is a problem, and you can live with only 1 drive, drill new holes in the mounting plate and mount the drive turned 90 degrees ccw. Refold the cable as needed.
You may want to locate the new holes, after figuring out how to refold the cable.
Bueno idea. I've seen the pix and that shouldn't be too difficult. One drive is all I've ever needed anyway.
Sucks not having the Empeg in the car...
Funny, how long it has taken for this technology to work its way up to production-based cars. Most of my friends have newer cars that still show track number and time...that's so "VCR"...
In fact, my closest friend's wife still uses a VCR...
-sTv
