You'll also do well by simply adding RF shunt caps around your sensitive nodes. Providing a path for the RF energy to ground - a 27pF 0402 cap is perfect for low-band GSM - can be a very simple solution to the problem.
Now imagine doing this where the transmitter and antenna are millimeters away and not moving smile
