At any time during all of this rewiring, did you verify that the wires coming from your car were doing the things they're supposed to do? For example, the wire that you think is 12-volts constant really is 12-volts constant, and the ignition switched 12-volt wire really is ignition switched 12-volts? Also, have you checked that you've got a really good ground?
