Use
perl -0777 -pe
The problem is -pe is going to go line-by-line, and "lines" are terminated by, well, newlines. The specifics of how the -0 command-line option work are rather arcane (unsurprising when dealing with Perl) but the net effect is you eat the whole file before trying to match.
Alternatively, setting
$/=undef;
before your pattern matching code will have the same effect (setting the record separator to consume the whole input stream.)
Edited by tonyc (14/09/2011 15:38)
