Get a good quality miniplug to two-channel RCA male cable. For best results you may have to solder a ground wire to the "outside" connector on each RCA plug and ground that to the empeg sled. The RCA plugs will, of course, connect to the AUX connector in the empeg wire bundle and can be selected via "source" at the top level menu.
Regards,
Mark
--> Get paid to surf the web! http://www.alladvantage.com/go.asp?refid=CCI498
