When ever my player reboots the visual stops and track pauses on the last song played. The only way to get the song to start is skip to the next song or fast forward. The other weird thing I noticed is Emplode only seems to find the player over Ethernet after I skip or fast forward the song.
I even tried rebuilding the disk with Mark's Big Disk builder and his 2.01 software with hijack. After that used maxfid and fidsift.
Any ideas?
MK2a
software version 2.01
Emplode 2.0
Hijack 515
empeg-car bootstrap v1.02 20001106 ([email protected])
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v515 ([email protected]) (gcc version
2.95.3 20010315 (release)) #2 Wed Jul 20 09:24:02 EDT 2011
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 40103262) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (996k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Found custom animation at offset 0x98378
Tuner: loopback=0, ID=-1
show_message("Hijack v515 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004b00).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x8080
ide_data_test: wrote 0xffff read 0x8080
ide_data_test: wrote 0xaaaa read 0x8080
ide_data_test: wrote 0x5555 read 0x8080
ide_data_test: wrote 0x0000 read 0xbfff
ide_data_test: wrote 0xffff read 0xbfff
ide_data_test: wrote 0xaaaa read 0xbfff
ide_data_test: wrote 0x5555 read 0xbfff
hda: ST9160821A, ATA DISK drive
ide_data_test: wrote 0x0000 read 0x0021
ide_data_test: wrote 0xffff read 0x0021
ide_data_test: wrote 0xaaaa read 0x0021
ide_data_test: wrote 0x5555 read 0x0021
hda: ST9160821A, 305245MB w/8192kB Cache, CHS=38913/255/63, LBA48
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0c:b
e
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting
player
Timezone: EST
Hijack: intercepting config.ini
hijack: removed menu entry: "Serial Port Assignment"
kftpd: listening on port 21
khttpd: listening on port 80
player.cpp : 385:empeg-car 2.01 2004/07/06.
Prolux 4 empeg car - 2.1434 Jul 5 2004
Vcb: 0x4086d000
Dead temp.sensor, status=0x00
Edited by Mitsu7374 (24/10/2012 23:51)
