In reply to:
There are a bunch of lame command lines around, so if you need one, let me know. If you decide to use lame, try to use the command line exe rather than the dll, because the dll hasn't changed much since 3.87.
I'd be interested in some of those lame command lines. I just switched to using the dll last week instead of the exe for the simple reason that whatever way I had the exe configured, it was taking about 30-35 minutes to encode a ripped .wav file compared with the dll ripping and encoding at between 0.5x - 0.7x (about 5 minutes for a 3.5min track)
(I'm using EAC 0.9 prebeta 11 and lame 3.89 MMX, encoding to 192k VBR)
Geoff
Got one of the first Mark 2 empegs...
