I don't know if the new BigDisk builder will stop you with the "Disk looks like it was already built" prompt on the serial port. Mark?
Note that this v6 builder will unconditionally destroy any existing files that it finds. USE WITH CAUTION.
So, the
v6 builder at least appears to just overwrite anything that's already there, which is what we want it to do in this situation. The serial output that Heather sees should say what it does/did.
The
v3 builder on the other hand.. may refuse to run if it sees a half-built drive.
