So now I’m going to look around my place for one of those surge protectors with coax connections in it. They said that might help.
That should work, but only if everything else in the setup is also plugged into the same power bar gizmo. This would tie all of the grounds together at a single point (more or less), eliminating any (ground) loops.
Or a ground isolator per K447, but you'll still want to plug everything into a common power bar to get rid of other loops.
