Actually if you just hold down 'Y' it works, just slow... If I can get my cat to lay on the keyboard just right, he'll sleep like that all day ... should get about half done ;-)
I found a work around for this by the way. You can add the number of "refs" for each tune as a column for the all tracks view ... then sort by this column. At that point it will allow you to delete large numbers of tracks at once
g.
RioCar (40Gig) Blue/Red/Green
'01 Audi A4 2.8 Quattro
