I've found a sort of bug when /etc/mtab is linked to /proc/mounts...
If you try to upload tunes when the link is in place, emplode will hang at the checking disc stage. After waiting a while, I got bored and reset the empeg and emplode and tried again, same result.
I use USB for uploads, so I connected a terminal to the empeg via serial and the reson for the hang is clear. fsck has raised a prompt about checking mounted discs being dangeous and are you sure (enter yes/no)...
I removed the link and fsck fails to find mtab, and therfore continues without the prompt.
So now you know.. =)
Jazz
(List 112, S/N 00030, 4 gig blue)
Jazz (List 112, Mk2 42 gig #40. Mk1 4 gig #30. Mk3 1.6 16v)
