I've been using the new version for a few weeks now and am very pleased with the results. Still a few problems, though, that seem to have already been discussed here and will hopefully be FITNR but here are some that I couldn't find mention of and wanted to check first before emailing the guys.
1. In emplode it used to be possible to make a copy of a track to another playlist and change the tag information to be different from the original. If I do this now the changes get reflected in both.
2. Search using PIN is stored so next time I press the search button it is still there. Pessing again means that I reselect that as a playlist. I have to cancel the PIN numbers before I can continue.
3. Pressing the 2 button should tweak my playlist by artist but it only seems to replace the next track with one from the same artist. Subsequent presses replaces the track after this and so on. Shouldn't it pull back all the tracks by that artist that are still in the playlist?
4. It occassionally freezes when in tuner mode. Keeps playing but I can't do anything without pulling the unit and re-inserting.
One final thing, how do I get rid of the 'Plays' information counter?
Otherwise - FANTASTIC!
Steve
2x80GB Mk II with Illuminated buttons
