Imagine you're 5 levels deep in your Playlists menu, then you change your mind and want to continue listening to the current track (yes, this happens quite often - I sometimes dive in for a look to make sure I'm not ripping a duplicate). Holding the Up button on the front panel sort of works, as it repeats. Doing the same thing with Cancel on the Rio remote does nothing. WIBNI if it at least repeated, and even better if holding Cancel (or Up) went right back to the top level (i.e. out of the menus and back to info/visual) immediately?
Toby Speight
030103016 (80GB Mk2a, blue)
030102806 (0GB Mk2a, blue)
