You're using exactly the same setup as I am and I have exactly the same problem. I have run a couple of these files through a Linux util (can't remember which one but it was recommended on this bbs) and it found problems and corrected them. I understand that it's the encoder that's used in the latest Musicmatch (I think I read it somewhere here). I also believe that the next release of Emplode will fix the files you've uploaded to the player, or at least fix the Metadata so you get the correct info for the file. Can anyone confirm this?
Marcus 32 gig MKII (various colours) & 30gig MKIIa
