Ok, here's a new thread so I don't keep posting to the CNC thread.
I'm done with the priming. I've been wet sanding with 2000 grit automotive paper. :) I'll now do a pass with some medium grit sandpaper to make some light scratches and then finish that off with the 1500 and 2000 grit again to smooth out those marks. Hopefully this will give me a nice brushed look when I apply the silver, instead of a dead flat finish.
I've also taken the powder coat off the handle and filled in the left divet with some epoxy. Needs more sanding still with a medium (400-600) wet paper, then a final sand and a clear coat.
Fascia alone
Fascia & Handle
