Here's the bug:
1. Emplode launched with multiple (2 in my case) playlists at the top level (right under the playlist item in the tree pane).
2. Create a new playlist at the top level.
3. Select the "Playlist" item in the tree view to show the top level lists in the right pane if not already shown.
4. Click on the second last playlist from the bottom (formerly the last paylist).
5. BUG 1: Note that the DOWN ARROW button is greyed out. Emplode still thinks this is the last item.
6. Click on the last playlist (at the bottom) which is the one you just created in step 2
7. BUG 2: Note that teh DOWN ARROW button is is NOT grey. Emplode thinks this item IS NOT the last.
8. Press the DOWN ARROW button.
9. BUG 3: Emplode generates an error and crashes.
Appologies if this has already been mentioned. I was just about to start a transfer before hitting the sack and thought I'd quickly get this online.
