Hi Tony,
What you want to do is to make a reservation for your empeg. Depending on what DHCP-server software you're using you can reserve a DHCP assigned address to a client by defining either it's WINS name (MS style) og MAC address (everyone elses style). Fortunately a MS DHCP server also supports MAC address reservation (it seems)
http://support.microsoft.com/default.aspx?scid=kb;EN-US;Q172408
Now you know that your empeg has the same IP address every time it on a particular network.
Now you can either configure your local DNS-server with a static entry pointing to the empeg, edit the workstations local hosts-file or just use the IP-address directly.
I hope this helps/works.
