ok, now i'm confused again. I read the FAQ section on the player not going into standby mode and it says
"If the player goes into full-power-off mode instead of standby mode, you probably have the Negative Spike bug. See the next entry (below) for a description"
the same entry says that if i have the wires switched, the player will keep playing instead of going to standby.
