In theory there's no way you can kill it, no. You can trash the flash, erase the hard disk, and still bring up back up using the correct upgrade files. The trick is that the re-flasher resides in hardware write-protected memory at the bottom of flash - this is the bit which witters on about letting fly the penguins of linux if you watch the power-up sequence :)
Hugo
