Interesting thread. I don't see any issues with putting them in the garage. The operating temperatures of the computers should keep them dry. I would place them in an enclosure of some kind. Maybe a cabinet with a temperature controlled damper. You can find these that are totally mechanical and quite inexpensive. Also maybe a switch and a filtered fan to work in conjunction with the damper to circulate air through the cabinet if the temperature rises far enough. I work for a major manufacturer and have seen systems running reliably for years in environments that you wouldn't believe! Good Luck and let us know what you decide.
No matter where you might be, there you are.
