Hi.
Fix? If a TA is meant to sound during a muted radio channel, then the Mute flag needs to be set to off during the TA and then reset to what the radio settings were after the TA is finsihed.
Probably easier to implement:
Simply have the player ignore the MUTE setting during TA (which probably set's a flag itself). So logically speaking, the sound should be muted whenever (MUTE && (!TA)). So, if you press MUTE, only the icon change should be happening during TA, and when TA is off again, the (possibly changed) MUTE setting should be in effect again.
Whether HUSH should be ignored during TA as well should probably be configurable. I prefer it to do so, but I understand those who still want hushed sound only when on the phone.
cu,
sven
proud owner of MkII 40GB & MkIIa 60GB both lit by God and HiJacked by Lord
